Springwatch in HD ?
Discussion in 'TVs' started by RecordablDVDfan, Jun 1, 2005.
  1. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    This is such an excellent series as last year (called Bill Oddie goes wild) which is what HD is really meant for. Does anyone know if this is being shot in HD by the BBC ?
  2. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    This is very unlikely though the BBC does have one HD capable OB unit,I believe.
    Feed for the show is in 4.2.2 on 1w sat.
  3. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    ok do modern satellite receivers like the Manhattan ST500 display these 4.2.2 feeds ?
  4. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    4.2.2 can be decoded by the Qualitv hd sat box and some pc software.Manhattan etc will not do it.
    Alan
  5. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    So is there s/w to do this for the Skystar 2 ? Could this be just a software upgrade for a satellite receiver ?
  6. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,110
    Manchester
    +713
    Not possible with normal satellite receivers - they don't have a suitable mpeg decoder that can handle 4:2:2 video.
    The QualiTV QS1080 is an exception ; studio type receivers costing form £2000 upwards can do this (Tandberg, Alteia etc) but they are not user friendly beasts ; I have a Tandberg System 3000 but I usually prefer to use DVBapps on a PC with 1 of the 2 PCI cards that I have .
    A PC card tuner can do it because the mpeg decoding is then done in software - though you probably need something like an 800 MHz or higher speed CPU.
    Chris muriel, Manchester.
