Spring has sprung in Finland
Discussion in 'Subwoofers' started by Nimby, May 7, 2007.
  1. Nimby
    Nimby
    Jan 27, 2004
    9,244
    The Danish Bacon Factory
    +700
    Ilkka has published a provisional table of results of his latest sub tests. :cool:
    No links. No pack drill! :devil:
    You should know where to look by now. ;)
    The PB12NSD is looking very strong! :smashin:
    SB12Plus is in there too! :)
    Nearly forgot to mention the Monolith!
  2. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    I wondered who'd be first to mention this.;)
    Russell
  3. Hungry Horace
    Hungry Horace
    Jan 11, 2005
    152
    +9
    The "other" forum has also posted their results.....:)
  4. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    The Rel T1s results look very interesting. Compare to it's precessor the Q200E. Goes slightly louder, goes a lot deeper with a lot less distortion.
    The same is also true when comparing the results to the B&W ASW-675 which I suppose is it's most likely retail competitor,The B&Ws sealed alignment does offer potentially greater in room extension, but in every other repsect the T1 bests it to a considerable degree.
    Russell
  5. Ilkka R
    Ilkka R
    Oct 20, 2004
    187
    28
    +40
    It may be better if I post the table here too. ;) Note that these are just some quick results. Full detailed results will follow.
    These are peak values which means that you have to subtract 3 dB in order to have RMS values. Sine sweeps etc. show RMS values.
    [​IMG]
  6. IronGiant
    IronGiant
    Jun 7, 2003
    66,440
    +46,644
    Thank you Ilkka :)
  7. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    The results are up! Seek them where-ever they may be.
    Russell
