Spray over. How much?
Discussion in 'Motoring' started by chriszzzzzz, Apr 28, 2007.
  1. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    Anyone know how much a spray over (not a complete rubdown job) would cost? I have a ten year old Honda Civic Coupe. It has only done 60,000 miles and has been serviced on time etc.
    I love the way it drives and to be honest don't want to change it. However the body work has all the usual swirls and scratches on it. Nothing major and no rust. I was wondering if anything could be done like a spray over, maybe one coat. I've been told to try 'mopping' but I don't think that that will do the job.
    Any advice appreciated....:)
  2. bu5ter
    bu5ter
    Oct 17, 2004
    2,166
    63
    Egham
    +116
    You cant just spray over and if anyone does offer it they are cowboys as it wont work. Trty mopping it basically this will take the cop layer of paint off and any light scratches should be taken away. Also alot cheaper a complee paintjob wil set you back anything from 600 to a grnad depending on whether you want door shuts and engine bay done etc
  3. Arcam_boy
    Arcam_boy
    Jun 13, 2006
    12,035
    2
    Birmingham
    +2,372
    If its only minor scratches etc why not try getting a decent polish and polisher and spending a day giving it a real good polish. You could try wet buff it or if your really confident rub the paint back a layer and polish it back up but this would probably require a professional to do this but something like Meguiars scrath X, polish and wax would do wonders with a decent electric polisher like a porter cable which can be had for $99 from the states!
  4. udsf
    udsf
    Jan 31, 2007
    395
    +16
    in fact i'm having my Grand done on Sunday - detailed/paint correction - to remove scratches and swirls etc
    should take about 10/12 hours at £25/hour
    i'll post some before and after photographs
  5. SteveTDCI
    SteveTDCI
    Oct 7, 2004
    1,090
    63
    +103
    www.detailingworld.co.uk have a look on there, if you only have swirling and the odd scratch you will find most of it will come out, and a decent respray will cost at least £1500 upwards. A detailing session will start at £100 +
  6. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    Your Grand what????? Where are you getting it done. I can't find any detailers in my area...
  7. udsf
    udsf
    Jan 31, 2007
    395
    +16
    sorry - Grand Cherokee
    its being done at my house by a local 'detailer'
    if you have a look on the Detailing World Forum on the Help thread it lists detailers and the areas they cover
  8. udsf
    udsf
    Jan 31, 2007
    395
    +16
    the guy who is doing mine will travel to Coventry if thats any use?
    there would be a £20 petrol charge - seems resonable seeing as he's travelling from North Notts!
  9. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    Thanks very much...I'll give this some serious consideration...:thumbsup:
  10. udsf
    udsf
    Jan 31, 2007
    395
    +16
    i could not believe the transformation! - and the glaze and wax are still to be applied
    recommend 'my' guy and detailing to anyone:D
  11. udsf
    udsf
    Jan 31, 2007
    395
    +16
    well its 11 hours later and all i can say is i'm gobsmacked by the end result!!
    i was going to spend money to have scratches touched up - ALL GONE -its saved me a fortune
    car looks better than new
    photos have been taken and i'll upload them on Monday
    after it was done he gave me a care sheet to maintain the finish - he did NOT sell the products and sent me to Halfords - total cost about £40
    then he threw out my crap 'care care' products!!
    if you are in doubt get it done - best money i ever spent on a car!!
    and now to get this Borla exhaust and Edelbrock suspension with the money saved!!
    btw when i post the photos please keep comments as to the finish not the cars nudge bars etc
    thanks:D
  12. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    So that was £275 plus £40 for the upkeep stuff? Very interested in seeing the pics.
    Does he do anything with the interior? I know, I know.:rolleyes:
  13. udsf
    udsf
    Jan 31, 2007
    395
    +16
    regarding price - because i had the full package of work there is an all in price of £230 - however he did it for £200 because he had an offer until 30 April
    the interior is vacuumed and cleaned - all plastic is cleaned and 'dressed' - and the leather was cleaned and 'fed'
    the only extra i imagine for a fabric interior would be for shampooing etc of upholstery
  14. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
  15. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    Agreed it would save money and can get it done for a tenner at the local hand wash. I just wondered if he did anything to the interior at the time he did the exterior. If not I would get that done first. It looks like he does though so great..
    Hurry up with pics UDSF..:)
  16. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    Any chance of the pics UDSF?????:)
  17. udsf
    udsf
    Jan 31, 2007
    395
    +16
    sorry - his pc has crashed:(
    fortunately the images are still on his camera so hope to have them later in the week
    as soon as i get them i'll mail them to you
  18. udsf
    udsf
    Jan 31, 2007
    395
    +16
  19. John
    John
    Dec 13, 2002
    11,635
    +3,304
    Wow
  20. udsf
    udsf
    Jan 31, 2007
    395
    +16
    if i was looking to invest in a new business i would certainly go for car detailing
    many top marque suppliers - eg Porsche, BMW, Mercedes, Ferrari etc are finding that new buyers are having detailing done pre-delivery
    strange that guys charging £25/hour can improve on the finish of a £250K car
    if you really want to see what can be done have a look at this link
    1922 Rolls Royce Silver Ghost - most expensive car in the world - according to Wiki up to $75 million insurance!!!
    http://www.detailingworld.co.uk/forum/showthread.php?t=11754
    if interested have a look at the detail a couple of forum guys did on a Bugatti Veyron!
  21. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    Not quite in the same league as Detailing World
  22. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    Excellent effort......:thumbsup:
    How long did that take you???
  23. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    It took about a day to do the interior and exterior.
    I tried to upload several more pictures but I don't seem to be allowed
