Question Spots / marks on the inside of LG TV
Discussion in 'LCD & LED LCD TVs Forum' started by Jurhoa, Nov 13, 2017.
  1. Jurhoa
    Jurhoa
    Nov 13, 2017
    4
    4
    Belgium
    I've had a LCD LG TV for around 6 years now and since recently (4 months or so) there are marks showing up rapidely between the glass and the screen. I have no idea what it is (see image). It's gradually expanding all over the screen. I didn't use any water or other products to clean it. I usely use a microfibre cloth. Anyone have an idea what it could be and if it is possible to remove the front panel and clean it? I know the TV is reaching it's life expectancy but the screen itself still functions well. It would be a waste to throw it away without trying to fix it.
    Thanks in advance
  2. ChrisKz
    ChrisKz
    Nov 13, 2016
    494
    46
    UK
    +138
    Damp air . lack of ventelation . try a de humidifier in the room
  3. Jurhoa
    Jurhoa
    Nov 13, 2017
    4
    4
    Belgium
    Ok, thanks!
  4. teatwosugars
    teatwosugars
    Oct 8, 2007
    247
    +77
    That certainly looks like mould.
    Is it on the inside of the screen?
  5. Jurhoa
    Jurhoa
    Nov 13, 2017
    4
    4
    Belgium
    It's between the front glass panel and the screen itself. No idea how it got there. Humidity could be an issue but I'm not sure. I wouldn't know where the humidity comes from. We do have a lot of plants in the house but I don't know if this makes a difference.
  6. ChrisKz
    ChrisKz
    Nov 13, 2016
    494
    46
    UK
    +138
    Probably . no windows open . having heating on causes condensation . A de humidifier would help to take moisture out of the room .. you would be surprised on how much . If it is not a room you sleep in .. close the door at night and switch a dehumidifier on all night , empty the water and do this for 4 days .. it will draw water out of the walls etc
  7. Jurhoa
    Jurhoa
    Nov 13, 2017
    4
    4
    Belgium
    Thanks for the comment. The TV is right next to a window that we open quite regularly but I will take your comment into account. I imagine the TV can't be saved but I just want to avoid this with the next.
  8. ChrisKz
    ChrisKz
    Nov 13, 2016
    494
    46
    UK
    +138
    yep .. looks like heat and cold ... You really need to move it away from windows as it goes from one extreme to another . If you have got mould in that TV , just think what else in in the room . Getting a dehumidifier would help your home in every room . Must be spores floating everywhere
