Splitting sky output signal
Discussion in 'Sky Digital TV Forum' started by Warp, Jul 19, 2005.
  1. Warp
    Warp
    Jan 5, 2005
    69
    Does anyone know if it is possible to get some sort of scart splitter that would send, say, the same sky picture to two different TV's?
  2. Cupra R
    Cupra R
    Jul 18, 2005
    75
    Warp, could you not just come out from the RF2 point on your Sky box via Coax to the other TV then also buy a TV Link to be able to switch channels from the other room?
  3. Warp
    Warp
    Jan 5, 2005
    69
    Thanks for your reply.
    I am actually using a wireless video sender to send pictures to another room (as wiring is not really an option). The video sender attaches to the sky box output via scart, hence I want to have my tv and video sender connected to the sky scart output at the same time so that I don't have to swap scarts all the time.
  4. Cupra R
    Cupra R
    Jul 18, 2005
    75
    Ok, sorry, I thought it wasn't as straight forward as I had first thought. Hope you find a solution. Is there not a scart kind of junction box, thought I'd seen something similar in the Argos or similar.. Not sure, just a suggestion.
  5. paulflowe
    paulflowe
    Have a look at the JS Technology Active Video Buffer. £45 + P&P but should be what you're after. i have a similar setup, but have the 'luxury' of a Tivo which has the twin scart-out (for want of a better term) already.
    Paul. :thumbsup:
