Splitting satellite outputs
Discussion in 'Cables & Switches' started by Deon, Jan 9, 2005.
  1. Deon
    Deon
    I need to split the audio and video signals from my satellite receiver (RCA connectors). Are there any problems with using a standard branching connector/splitter, and can I spit it twice (to 3 devices)? I want to take it to video recorder, TV and a projector.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Each device that you hang on the end of the connector will load it. Outputs are designed to drive one load, not three. This could result in lower sound output (which you can probably compensate for), but it might also cause darker pictures, and maybe even picture sync problems. If this does occur, you will need a line amplifier.
