splitting s-vid
Discussion in 'Cables & Switches' started by squid, Jan 16, 2004.
  1. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    Just got a nice dvd player off ebay . prob is did'nt relice that it was an import and has no scart . It came with a s-vid to scart lead but I need to have an s-vid out for the projector and scart for the new tv that's on it's way .
    So I need the best way to split the s-vid out so I can connect the s-vid to scart and an s-vid to s-vid cable . Anyone got a link to a cheepish but good quality s-vid splitter
    thanks
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,418
    The Borders
    +2,591
  3. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    thanks joe .Little more expensive than I wanted realy though. Just got a new amp with s-video ins and outs . I'm thinking of using the monitor out and a video out to run to the projector .I think this should work ok and save havin another box
    Thanks for the info though .I apresiate you taking the time :smashin:
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,418
    The Borders
    +2,591
    Hello squid
    Your AV Amps twin outputs should do the job as long as the cable up to projector is not too long - as the AV Amp wont be designed to drive a long cable.
    Best regards
    Joe
  5. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    cheers .
    Don't think I will have that problem though as I am getting an iscanpro from somone on the forums so should only need a short run in to that and then a longer vga cable to the projector
    I'll be able to get some nice reg one films then as the sony dvd I have now has lots of nice outputs but is saddly reg2 only :( . once I have my new (well newish) pioneer DV-525 connected up I
    will finaly ( i'ts about time ) be ably to enjoy the wonderes of reg1:clap:
