Hello everyone I’ve got a simple question - I want to split front channels LR into two each with simple Y rca cable. Then connect those to two separate amps (PA410) for each channel (one for L one for R) and this way to bi amp (separate channel for hf and lf). I think there should be no problem with doing it this way unless…? Currently bi amping speakers via AVR20 and definitely there are more details present when doing so compared to running via single amp. I’ve got 2 PA410 which typically would be used for atmos channels but I think those amps are better quality amps compared to integrated ( thd over 1khz and 80% power is nearly 7 times lower for instance).
Also total cost of those two amps was like 1000 so I think that is not too bad price either and would be rather hard to find anything better in same price range that would allow me to bi amp speakers.
Btw I have KEF R3.
Any advice appreciated
Btw I have KEF R3.
