splitting component output
Discussion in 'Cables & Switches' started by malariaboy, Jan 23, 2005.
  1. malariaboy
    malariaboy
    Dec 16, 2002
    1,897
    taunton somerset
    +120
    can anyone tell me if theres a cable that i can plug into the component out of my denon 3805 that will enable me to plug 2 component leads in. as i use one to the plasma and would like to run the other to the projector
    thx darren
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,088
    malariaboy -
    You can add 'T-Piece' connectors to 'split' your YUV output; though I wouldn't advise it. Your going to degrade the signal your delivering to your TV and Projector.
    You really need to contemplate a signal Distribution Amp (DA) and depending on what length of cable is going to your Projector you may want one with an inbuilt 'line driver' to drive long cables.
    Unfortunately DA's (with line driver) are not inexpensive - normally around 350.00 GBP.
    You can use a Zektor HDS4 Switcher 'reverse wired' to enable you to switch one source to up to four displays; though your still looking at nearly 250.00 GBP. See http://www.zektor.com
    How does the projector fair with the S-Video outputs from your SKY+ and DVD player? Possibly a decent S-Video cable to the PJ will suffice
    Best regards
    Joe
  3. johnsattuk
    johnsattuk
    Nov 27, 2003
    191
    Tamworth West Mids
    +5
    I had a similar requirement, which I solved with a 4 input x 2 Output Matrix switcher.
    It has 4 inputs and you can remotely switch any input to any output. It switches YPbPr and L & R video. I am actually using it to switch RGBHV using the audio switch for the sync.
    Works wonderfully and gives a great deal of flexibility. it cost appro £120 deliverd from US
