SandsofEss
Hello again,
One final question. It turns out that we do have an aerial mounted to the roof.
At the moment, this enters the loft as a single cable. I've not been able to look at it myself yet, but I suspect it's standard RF stuff.
As a short- to mid-term fix, I am considering chopping into this cable after it enters the loft, splitting it, and then running it as two separate feeds to the rooms below.
I will be running WF100 cable down to the same rooms from the satellite dish. Does it make sense to also run the standard TV cables as WF100 (and indeed, is it possible to split from standard TV aerial cable to two WF100 cables instead)?
I presume that the quality will still be limited to whatever the original entry cable can carry, but this solution (if possible) at least gives me the option of upgrading my aerial at a later date without having to mess with my connections to the rooms below.
Or would I be better off just running it all as RF.
I'm also presuming that I won't need to get any kind of powered or amplified splitter, as it's only two signals and the split cables will both run to around 6 metres each. Is this correct?
As always, thanks for your time.
Steve
Steve
