splitters
Discussion in 'Cables & Switches' started by dlemon, Jan 7, 2012.
  1. dlemon
    dlemon
    May 5, 2009
    117
    Bangor, Co Down
    +4
    Hi, I have got new tv and amp, and both are ethernet enabled, but what I was wondering, is there such a thing as a ethernet splitter and do they work, I have a cable running from my router to the back of my SKY+HD box, can this be split, into one to the amp, and one to the tv, as I dont want any more cables running around the door frame as there is already 2 there to the sky box. If yes you can, who would do them, is it as simple as getting them from argos or somewhere.
  2. DIYlady
    DIYlady
    Oct 13, 2009
    2,158
    116
    Ascot
    +1,984
