Splitter
Discussion in 'General TV Discussions Forum' started by Michaelknell, Sep 2, 2005.
  1. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    I have a HDTV, but the HD runs thorugh DVI like many do. The thing is, I would like to have my PS3 and SkyHD connected to the TV as well as possibly a DVD player. The problem here is that I need a DVI - HD converter. I'd like to buy one that can hold up to four HD connections so that I can connect four HD wires to one splitter. Then connect the splitter to my HDTV via DVI wire. I have found only one for sale so far. This was on eBay and was priced at £300. Anyone know if there are anymore or if there will be closer to when HD is more widespread?
  2. scarty16
    scarty16
    Jul 1, 2003
    1,406
    +304
    Meridian will have two soon, probably won't be cheap!!
  3. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,351
    +812
    Gefen seem to make 4:1 HDMI switches, and as long as you can sort the audio, and your DVI TV supports HDCP then you should just be able to use an HDMI to DVI cable and an HDMI switch?
    (DVI and HDMI are electrically compatible for video, but use different connectors, and HDMI includes HDCP encryption which is optional for DVI.)
