Split screen picture when HD used on X-Box
Discussion in 'Nintendo Forums' started by tony @ suffolk, May 24, 2005.
  1. tony @ suffolk
    tony @ suffolk
    Aug 9, 2004
    711
    stowmarket
    +37
    Hello folks.
    I've just posted this on the Sim2 Owner's forum -
    "I recently modified my X-Box games console to HD output. This was done via a "Soft" mod., which switched the Box to NTSC and then HD through Component output. I then bought a Component/"S"/Composite to HDI convertor, which feeds into the HDMI input on the Sim2.
    If I use the component output from my DVD player into this convertor, the picture's fine, and it's fine from the X-Box until I switch this to HD. I get a picture, but it's two images side by side on the screen.
    I would appreciate any help on this!"
    I'm pretty certain that I've read of a similar thing somewhere on the Forums, but can't sem to find it.
    Thanks in anticipation!
  2. -Spike-
    -Spike-
    May 17, 2001
    1,514
    E.Sussex
    +218
    Tony,
    I posted on this a few weeks ago. Jeff has replied.
    Please see the Sim2 Forum.
  3. tony @ suffolk
    tony @ suffolk
    Aug 9, 2004
    711
    stowmarket
    +37
    OK, thanks for this Spike!
