Splinter Cell hack is not valid xbox save. HELP!
Discussion in 'Xbox Forums' started by Wilt, Mar 29, 2005.
  1. Wilt
    Wilt
    May 13, 2004
    1,021
    48
    Mitcham, Surrey
    +30
    I'm trying to enable prog scan. Managed to download save, loaded up maxdrive software from datel and tried to drag the splinter cell save onto PC drive section, but it says the above. Anyone? :lease:
  2. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    Drag zip rather than contents of zip ??
  3. rimibar
    rimibar
    May 17, 2003
    463
    Cambridge
    +10
    Have you unzipped Splintercell.zip? Within there are 2 more zips - these are the ones you want to copy. Good luck!
  4. Wilt
    Wilt
    May 13, 2004
    1,021
    48
    Mitcham, Surrey
    +30
    Thanks guys. Problem sorted. :)
