spl setting
Discussion in 'Home Cinema Speakers' started by barrykil, Jul 8, 2002.
  1. barrykil
    barrykil
    Jan 17, 2002
    2,380
    48
    +26
    messing about with radioshack spl meter do you set the weighting to a or c for hc set up and is it 73 out of all speakers what about the sub? thanks for any advice
  2. LostInUK
    LostInUK
    Sep 1, 2001
    103
    16
    Lisbon
    Hi barrykil,
    You should use the C weighting filter, and it is 75dB for speakers. For sub I recommend you around 78dB. Nothing like trying by yourself to see if it sounds natural or not. I hope it helps.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    I gave up trying to set the sub with an SPL meter ages ago. When the meter says that the sub level is correct it is barely audible.
  4. LostInUK
    LostInUK
    Sep 1, 2001
    103
    16
    Lisbon
    Not sure how good your SPL is with low frequencies, and usually they are not that good.
    Anyway, that is nothing from normal, as it is not that usual to listen to the sub that frequently during music listenning. The contrary with HT. :)
    It all depends on the crossover frequency you use. If you use something like 50Hz, I am sure you will not hear it omnipresent.
    When I wrote an email to the technical deparment of the company that produces my AV processor, asking for setup instructions, I got a reply saying that sub should not be intrusive in a properly setup system. Also, to FINE tune it by listenning after a first approuch using SPL. But, if I intended my system to be correctly setup, bass should sound natural and it would not be as listenable as I expected.
    If your SPL is able to read sound pressure at the sub setup tone (some are not), I think that at least it may give you an indication where to start.
    My oppinion.
    Bests.
  5. barrykil
    barrykil
    Jan 17, 2002
    2,380
    48
    +26
    thanks for your replies and advice cheers
