spl meter
Discussion in 'Home Cinema Speakers' started by mw3cdj, Mar 31, 2003.
  1. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    Hi all,
    nearly finished my new hc room :clap: and it will soon be setting up time.What i need to know is do i point my spl meter at each speaker in turn or do i leave it facing forward.
    thanks for any advice.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    You should have the soundmeter pointing upwards with it in your listening position as you test each speaker.
    Vikki
  3. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    As in vertical , or at an angle ???
  4. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    Is this also the same for the sub, and do i set the sub up for the same spl reading as the rest of the system ???
  5. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    I use my SPL pointing directly at the celing, though off vertical, slightly towards the front speakers, is also ok, from what i understand. Sub wise i tend to set the level by ear, then once i'm happy i take an SPL reading...so i can easily reset things after my 20month old has tweaked the system. The Dolby spec's _i think_ allow for the sub to be 10dB above the rest of the speakers.
  6. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    ok, let me get this. You set the sub for 10db higher than the rest of the individual speakers?? is that right?? Sorry to sound a bit clueless but i want to get this right.
    thanks.
  7. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    Dolby allows for 10dB, and yes that's above the rest of the speakers, but personally i find this a little over the top.
    By ear, and depending on sub, i tend to arrive at settings from 0dB to around +7dB, with respect to the other speaker.
  8. nathan_silly
    nathan_silly
    I point the SPL mic at each speaker in turn.
  9. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    ok.looks like there are two schools of thought here.Is this a case of suck it and see or is there some logical explanation why some people do it one way and others a differant way?? Which way do dolby recomend?? Can't find anything on the dolby site ! any thought's??
  10. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    The instructions that came with my radioshack meter say
    "For the most accurate readings and the best polar response, point the meter's microphone towards the sound source when possible."
  11. bob007
    bob007
    Just to confuse matters, here's Rotels view on how it should be used. ;)
    Calibration
  12. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    Now this is getting confusing:confused: Think i'll just set it up by ear.
    Thanks for all the feedback.
