SPL Meter
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by JetJockey, Oct 10, 2004.
  1. JetJockey
    JetJockey
    :offtopic:
    Any recommendations? The instrument of choice used to be the Maplin Analogue SPL meter but they don't stock it anymore! They sell a Maplin Digital SPL meter now. Is this any good?
    Many Thanks, Gerald. :)
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    I think the SPL of choice on here has been for a fair while the 'Radio Shack' analogue SPL. This is still available but getting quite difficault to track down stock.
    I've got the Maplin digital SPL and it is good enough for setting up a HC system, but can be a bit inaccurate with the subwoofer. In the past I have got the sub to a level I like just by my own judgement rather than useing the SPL and therefore the inaccuracy has never been a problem. As I say, for all your other speakers the SPL from Maplin will be as accurate as you need to get a balanced sound from the speakers.
    Mark.
  3. cosaw
    cosaw
    Jun 14, 2003
    753
    Stockport, Manchester
    +20
    Just did a quick search, the first link that comes up quotes £30 for the radio shack analogue.
    See url: http://www.cornwallelectronics.co.uk/
    I presume they only do this one? The scale goes down to -10db I would have thought it would go down to -12. Don't suppose this matters, its probably the one I'm getting anyway.
    How much is the Maplin digital one?
    Simon
  4. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    Got mine from cornwall electronics, its the right one and is meant to be a lot better than the digital ones.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    Details of the Maplin SPL are Here
  6. cosaw
    cosaw
    Jun 14, 2003
    753
    +20
    owain just before I make a final decision - what are the advantages of the analogue over the more expensive digital? Radioshack do a digital version as well you see. Also is your version the newer analogue version and if so does it still need the correction tables (incidentally do you know if the digital version needs the correction tables?)
  7. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    When I was looking for mine all the threads I read said that basically the analogue one was more accurate. Mine does need the correction table, it has a manual with it that shows this. Don't know if the digi one does, not heard of many people using them.
    hth
    owain
  8. cosaw
    cosaw
    Jun 14, 2003
    753
    +20
    Thanks owain, I'll probably go for the analogue one then from the same place you got yours. Apparently there is a mod you can do (involves changing capacitors) which does away with the need for the correction table by improving the units performance. Not sure how effective this is but I can probably find you the link if your interested?
    Simon
  9. JetJockey
    JetJockey
    Hi.
    Would be very interested. Can not track down the Tandy Analogue SPL meter anywhere. Anuone know of stock?
    Thanks, Gerald.
  10. cosaw
    cosaw
    Jun 14, 2003
    753
    +20
    Here is an article on the mod:
    http://www.stereotimes.com/acc032902.shtm
    Here are the mod details (sub-link):
    http://www.gti.net/wallin/audio/rsmeter/33-2050/33-2050.html
    I don't think the Tandy name exists in the UK anymore. Aren't they the same company as Radioshack - I'm not sure myself? The top result of this search states "Cornwall Electronics Formerly Tandy Truro" and they stock the Radioshack spl meter:
    http://www.google.com/search?hl=en&lr=&q=radioshack+spl+cornwall+tandy
    Hope this helps,
    Simon
  11. JetJockey
    JetJockey
    Thanks for the mod details.
    Unfortunately, Cornwall have no stock. :eek:
    Gerald.
  12. spm
    spm
    Jun 22, 2004
    190
    +9
    they are shown online at Keene Electronics www.keene.co.uk at £25 + pp, I don't know if they are in stock
  13. cosaw
    cosaw
    Jun 14, 2003
    753
    +20
    Sounds like a bargain spm, I'll have to check that out!
  14. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Analogue is regarded as better so you can see trends more easily (like on a car speedo).
    I've yet to find any information showing what the correction values are for the new Radioshack meter and similarly I'm not sure if the mod is possible or even worthwhile on the new model.
  15. flamingoboo
    flamingoboo
    Jun 4, 2004
    125
    +3
    Just ordered an analogue one from keene, i'll let you know how I get on with it when I unwrap it tomorrow.
    Bhusan.
  16. cosaw
    cosaw
    Jun 14, 2003
    753
    +20
    Me too, just ordered analogue from keene. Ready to plot main speakers and one step closer to building an active crossover for my stereo subs - for when I've built them...and I've purchased a power amp...............and when I've expanded my very basic knowledge of active crossover construction, give me 6-8 months perhaps ;)
    Simon
  17. flamingoboo
    flamingoboo
    Jun 4, 2004
    125
    +3
    Just have to make a special meion for KEENE. I ordered my unit on wednesday and paid £8.00 for next day delivery....The next day(yesterday) nothing so I called Keene who looked into it and came back to me five minutes later to tell me that the delivery company seemed to have lost it. The nice chap on the end of the phone said that he would send one right away and would arrive here today as well as reimbursing me my eight pounds. Lo and behold... 7:30 this morning...courier...spl meter.
    Great customer service they had a problem and dealt with it straight away with no fuss.
  18. cosaw
    cosaw
    Jun 14, 2003
    753
    +20
    Good to hear that flamingoboo, I recieved mine this morning (Sat 16th) from Keene, I order it second class on Wednesday evening so I'm well chuffed. It's smaller and lighter than I thought which is nice.
    A quick check of the rolloff of my 1980s refoamed technics sealed speakers without correction tables shows a response flat down to 70Hz with a -3db point of 65Hz in room. The manual specs quote -10db at around 42Hz, they seem to be a little down on this relatively when testing at 40Hz but as I say I've not used any correction tables, I'm going to look into that now. The speakers by ear have very good bass extension in my opinion compared to alot of modern speakers I've heard. Even so they start rolling off after about 70Hz. Some of the specs quoted for modern high street average price speakers are obviously nonsense.
    Have to get to grips with the correction values and get testing :)
    Simon
  19. Grif
    Grif
    Jul 28, 2004
    269
    +4
    Just got one of these myself....anyone know if the correction values are relevant to this meter since they've redesigned it? Also notice the manual recommends pointing the mic directly at the sound source, not up in the air, which is presumably why the tripod mount is on the back now, instead of the base.
  20. cosaw
    cosaw
    Jun 14, 2003
    753
    +20
    Grif:
    The concensus seems to be that you'll still need the correction values. I've been using them and have made test tones to correspond to the relevant frequencies.
    Cosaw
  21. Grif
    Grif
    Jul 28, 2004
    269
    +4
    Wow...how'd you do that! I'm struggling a bit with my DVE disc as its only got a frequency sweep, which is too fast.
  22. cosaw
    cosaw
    Jun 14, 2003
    753
    +20
    Hello Grif,
    This is the way I did it. Download this small free function generator:
    http://www.marchandelec.com/ftp/fg_lite.exe
    This allows you to create sine waves at whatever frequency you want. Just type the desired frequency in and press enter.
    Use your normal volume contols (not the ones in the program - I find this easier) and make sure you keep the volume the same.
    Use the correction values and create tones at the relevant frequencies:
    http://www.danmarx.org/audioinnovation/rsmeter.html
    As the tone is playing in FGLite, record about 10 seconds with the sound recording software you probably got with your soundcard - soething like Creative Labs WaveStudio. Alternatively find a freeware version on the net.
    Save each 10 second recording as a wav file and burn all the files to a music cd to play on your stereo. Note: When playing these tones on your stereo keep the volume down (I aim for about 70db and that's less than one watt on my watt meter) if its too loud you risk burning your tweeters out with a continuous sine wave.
    I'd upload the tones I created to some webspace but there's about 60megs worth and I'm on 56k, reducing the quality of the files introduces alot of hiss so I think this would be unacceptable.
    Hope this helps,
    Simon
  23. Grif
    Grif
    Jul 28, 2004
    269
    +4
    Thanks Simon....very impressive! I'll give it a go when I get some time.
