SPL meter...Cheapest price
Discussion in 'Home Cinema Buying & Building' started by fire boy, Mar 10, 2005.
  1. fire boy
    fire boy
    Dec 14, 2004
    285
    London
    +7
    Hi guys
    I just borrowed an SPL meter to help calibrate my system Wow what a difference!!! :thumbsup:
    I now want one of my own but after searching the net I can't see any cheaper than £55. :thumbsdow
    Can anyone tell me if and where I can get one cheaper or better still a power buy on this Forum?!
    Any advice will be greatly appreciated.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  4. Zone
    Zone
    Jun 24, 2001
    6,736
    Barnsley
    +2,424
  5. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    Yes I ordered one from Nick Sheppard last week at the £24.99. Arrived the next day. No delivery charge - Excellent.
  6. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    Any idea of the frequency range please ?
    I'd like one that I could setup my Sub with also.
    Thanks, Mark.
  7. cinemagary
    cinemagary
    Jul 27, 2004
    494
    Manchester
    +16
    How easy are these to use where do you place them etc:confused: would it be best to get the one for £24.99 or the one for £39.99 from nicksheppard. Any advice would be appreciated. :)
  8. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    The owner's manual states that the meter measures uniformly over the frequency range of 32 - 10,000Hz (C weighting). It would be useful for a sub but not if you really wanted to measure the lowest frequencies. There is a correction table for the RadioShack meter on the forum but I don't know if it applies to the newer meter (which I think this is).
    To use the meter to set up your system you simply locate it at your listening position at ear height. The meter has a tripod adapter for "hands-free" operation.
    Most people recommend the cheaper analogue meter as it is easier to read in this application.
    BR
    David
  9. cinemagary
    cinemagary
    Jul 27, 2004
    494
    Manchester
    +16
    I ordered an SPL meter at £24.99 :) from Nick Sheppard yesterday, it's already arrived !!! :D brilliant service, thanks Nick :thumbsup:
  10. mark pallister
    mark pallister
    Mar 1, 2005
    88
    me to,ist class service!!
  11. osmyth
    osmyth
    Nov 10, 2002
    281
    16
    York
    Mark/Gary, how easy is it to use and has it made a noticable difference?
    thanks, Owen.
  12. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Ebay- got one for £12
  13. cinemagary
    cinemagary
    Jul 27, 2004
    494
    Manchester
    +16
    Its fairly straightforward just follow the instructions, or search via www.homecinemachoice.com there is advice on how to use them. It really does make a difference :thumbsup: well worth £24.99 inc postage from nick sheppard:thumbsup:
  14. pj
    pj
    Mar 15, 2002
    2,435
    117
    w.mids
    +501
    found a new shop called technology factory who stock the radioshack range and they do the digital spl for £39.99 and the analogue for £29.99 afaik there are shops in stourbridge and worcester www.ttfl.co.uk might be a bit more than online but atleast u can go in and have look first
  15. jmnormand
    jmnormand
    corrections for the analog radio shack meter can be found here
    http://www.danmarx.org/audioinnovation/rsmeter.html
    suspect this will work with any of the anlog versions but cant say for sure if they have changed the actual componets in newer versions.
  16. kraal
    kraal
    Aug 23, 2004
    103
    Portugal
    What you think about the digital models that can be found at a good price on Ebay?
  17. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  18. kraal
    kraal
    Aug 23, 2004
    103
    Portugal
  19. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    It seems to tick all of the right boxes for basic calibration purposes. :)
