spl meter and 3802 settings seem to differ
Discussion in 'AV Receivers & Amplifiers' started by mick23, Apr 5, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    just tried setting up denon3802 with radio shack anolouge spl meter i set to range 70 c weighting slow mounted spl on tripod at the listening position 45degrees up in a line to center speaker ran test tone set speakers to 75db if i set to vcr1 pl2 on front display of denon and adjust levels to 75 they seem to be totally different settings than selecting dts for example what input if any should i set denon to dvd dts or whatever read thread test tone outputed from denon is same for all modes but i seem to be getting a lot of difference in readings i turn master volume fully left before taking readings thank you
  2. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
    Hi mick23. I have just got a Denon 3802 and am also in the process of setting up the levels. It is fairly easy to do, however the manual does make it sound like rocket science. Just set the remote to Amp. Press the reciever button on the remote until the AMP word appears. Press setup. A menu appears. Go down the list setting things as you go.Press enter at the end of each section to store the changes. The speaker distance settings and levels in this sub menu are global and effect all sound settings. Take your spl meter readings here not in any speacialist DSP modes. Remember to take the first reading on the SPL meter from either your main front left or right speaker and set the volume using the volume control to show 75db on the meter. Then set all other speakers keeping the volume button untouched.
    Hope this helps. Its a good amp the 3802, do you agree??
    Mark
  3. mcmullanbrush
    mcmullanbrush
    Apr 20, 2002
    1,137
    39
    rotherham
    i am about to set my denon 3801 using a radio shack analogue sound meter so i would be grateful if i can bother the two of you for advice when i manage to cock the whole thing up
