spl meter analogue or digital
Discussion in 'Home Cinema Speakers' started by adox, Apr 14, 2003.
  1. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    probably been asked before, but i am about to purchase an spl meter and was wondering was a digital one worth the extra expense, or will an analogue one suffice?
  2. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    bump
  3. nathan_silly
    nathan_silly
    Analogue is supposed to be more accurate, but because digital has a large display it's more easily readable from a couple of feet away.
    Whether or not the digital one is alot less inaccurate or only slightly out- dunno about that.
    I have the Radio Shack digital one (cost £20 or £30) when Tandy were closing down their shops.
    I think the digital one has a couple of features the analogue one doesn't have- it has an average, minimum and maximum level.
  4. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    thanks for the reply nathan. i`ll go with the analogue and see hoe i get on.
    thanks again:smashin:
  5. kryten
    kryten
    Apr 9, 2003
    557
    Swindon
    +18
    I've always used the analogue. It seems pretty accurate, even when using the output to connect to a PC running analysis software: pretty close to and audiocontrol RTA after applying correction....
  6. Repton
    Repton
    Mar 1, 2003
    1,211
    Wirral
    +135
    in plain English?...
  7. kryten
    kryten
    Apr 9, 2003
    557
    Swindon
    +18
    <english>its pretty accurate, even when directly compared to a few grands worth of audio signal analyser with a +/- 0.5db calibrated microphone, as long as you allow for its innacuracies which are shown on the correction graph in the manual that came with the meter.</english>
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I have both the analogue and digital sound meter from Radio Shack, there is really very little in it, other than they all read differently!
  9. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    thanks for the replys. analogue one on the way as we speak.
    thanks again.
  10. crooksm
    crooksm
    adox - please let me know where you are getting your meter from and how much you paid. The only one I have seen is a digital one from Maplin for £50.
  11. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    www.cornwallelectronics.co.uk
    about £25 for the analogue one
