spks/sub/rec for tosh 42wh18b?
Discussion in 'Subwoofers' started by baldeagle, Feb 18, 2002.
  1. baldeagle
    baldeagle
    Looking to upgrade tosh 42wh18b with better speakers and amp/receiver. Problem is the rptv hasnt a lot of room on top to set for centre speaker, so it needs to be sleek looking!
    Also on a tight budget but want sub woofer included. Dont want to spend much more than £800 for lot. Any suggestions. (I already have SD210e DVD player).
    Package deal would appeal as im not sure i want the bother of piecing a jigsaw together!
    Cheers.
