Spinning colour wheel in safari
Discussion in 'Apple Forum' started by square-eyes-baz, Jan 9, 2012.
  1. square-eyes-baz
    square-eyes-baz
    Mar 18, 2006
    1,605
    Milton Keynes
    +189
    For the last couple of days on our Imac i keep getting the spinning colour wheel while using Safari. It wont go on its own so i have been force quitting Safari. One thing, for example, that sets it off is if i open another tab ltohugh it can just come on anytime.
    Ive searched the net and most answers say to open Activity Monitor. at this point im already out of my depth, basically i need some help (in simple terms:D) thanks
  2. Christ
    Christ
    Dec 15, 2002
    275
    Yorkshire
    +18
    When I've had that problem, a complete Safari Reset & Empty cache (for all users) fixes everything.
  3. square-eyes-baz
    square-eyes-baz
    Mar 18, 2006
    1,605
    Milton Keynes
    +189
    Forgot to mention, I did empty cache but i havent reset Safari, Ill give that a go, thanks.
  4. square-eyes-baz
    square-eyes-baz
    Mar 18, 2006
    1,605
    Milton Keynes
    +189
    OK, reset Safari, opened a few pages then I clicked the little bookmarks icon and the spinning wheel appeared again.
  5. BandofBrothers
    BandofBrothers
    Oct 25, 2005
    3,071
    +174
    Is safari your only application with this problem?
  6. square-eyes-baz
    square-eyes-baz
    Mar 18, 2006
    1,605
    Milton Keynes
    +189
    Yes, so far.
  7. square-eyes-baz
    square-eyes-baz
    Mar 18, 2006
    1,605
    Milton Keynes
    +189
    Also, don't know if this is connected, but when i open another tab it opens to History instead of Bookmarks menu now.
    I've asked my kids if they've downloaded anything while I've been at work and they assure me they haven't..
  8. jamiesdad
    jamiesdad
    Jan 3, 2008
    593
    46
    Scotland
    +108
    A long shot but do you have MacKeeper installed?
  9. square-eyes-baz
    square-eyes-baz
    Mar 18, 2006
    1,605
    Milton Keynes
    +189
    Not to my (limited) knowledge)
    Ill have a search in case
  10. square-eyes-baz
    square-eyes-baz
    Mar 18, 2006
    1,605
    Milton Keynes
    +189
  11. jamiesdad
    jamiesdad
    Jan 3, 2008
    593
    46
    Scotland
    +108
    Thought it would be a long shot. I had a similar problem and after uninstalling MacKeeper all was well
    good luck
  12. square-eyes-baz
    square-eyes-baz
    Mar 18, 2006
    1,605
    Milton Keynes
    +189
    I dont know yet if deleting that folder has cured my problem for good but its been ok so far.
