Spilt scren with a HD-DVD
Discussion in 'Xbox Forums' started by Johneb, Dec 24, 2006.
  1. Johneb
    Johneb
    hi
    Guys simple question - I have seen a bit of footage where you can have a split screen with SD one side and HD the other. How do i get this?
  2. Johneb
    Johneb
    just found out that U-Control is supposed to be in the menu on the HD-DVD disk - but I dont have it on mine. I have Play, Setup and scenes. I guess this is meant for US models????
  3. blicky_1
    blicky_1
    Jan 23, 2006
    2,979
    Hampshire
    +516
    Either the footage has been edited or the TV is capable of split screen (2 inputs at the same time)
  4. blicky_1
    blicky_1
    Jan 23, 2006
    2,979
    Hampshire
    +516
    I guess you have the UK King Kong?? if so U-Control is only available in the US version of this film.
  5. Johneb
    Johneb
    cheers blicky
