Spikes worth it?
Discussion in 'Subwoofers' started by arn, Jan 26, 2005.
  1. arn
    arn
    Dec 26, 2003
    270
    Bury
    Is it worth putting spikes on my sub? at the moment it's on carpet with a concrete floor underneath.
    The sub is part of the nsp100 set
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    If it has decent rubber feet that should probably be all that you need
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    As Ian says, I wouldn't worry too much as long as it's not directly on the floor where it will get dusty. :)
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    If its just sitting ont he carpet with no feet then getting some spikes on it will make a difference. Richer sounds and maplins sell spike kits for arround £5.
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    I'd agree with this. Must be better than rubber feet wobbling around on carpet pile...PJ
  6. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I agree with all of the above too, spikes or decent feet make a big difference.
  7. belgrade
    belgrade
    Mar 4, 2004
    137
    16
    newcastle
    What do you class as decent feet? My xls200-df came with a pack of spikes, even though the sub was fitted with puck-like feet (I think they are rubber).
    Do you think attaching the spikes to the bottom of the feet would improve things, or should i just leave it alone? The sub sits on a concrete slab at present.
  8. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    If it's on a concrete slab the rubber/plastic(?) feet should be fine. I have mine on spikes to get through the carpet to the concrete floor...PJ
  9. stevefish69
    stevefish69
    Jun 25, 2004
    4,227
    +439
  10. arn
    arn
    Dec 26, 2003
    270
    Bury
    :oops: it doesn't even have rubber feet, so i guess spikes it is then
  11. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I use some doorstops as a good alternative to spikes. They're the right size, consistency and strong enough for the task, have a useful screw hole through the middle and are cheap too. :)
