S
ScoobyDoo69
hey guys, could someone tell me the advantages of using spikes? and if I should put them on my floor standers? also what difference will this make?
cheers
ScoobyDoo69
cheers
ScoobyDoo69
Knightshade said:Make sure you stand the speakers with spikes on some pennies or if your feeling flush £1 coins.
mdinch said:I used have my Gale 4i's on spikes on pennies on hard flooring. Very difficult to set up. I now have them sitting on top of a couple of large ceramic floor tiles. Simply place the tile wherever you want to locate your speaker. Then gently set the speaker on top of the tile. This also has an added benefit of improving the sound quality from your speakers all round. My base response improved dramatically.
For those people with carpeted floors, I recommend placing a couple of paving slabs under each speaker. A friend of mine done this a couple of years ago and she couldn't believe the dramatic difference it made to the sound of her TDL speakers.
Ceramic tiles and paving slabs are cheep enough. Experiment. You may find that it works for you too.
