Spikes on a laminate floor
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Igwiz, Jan 3, 2005.
  1. Igwiz
    Igwiz
    Dec 12, 2004
    35
    Hi all,
    I think I have decided on a Alphason audio stand for my equipment. My only concern is it has spiked feet and it will be sitting on laminate flooring. What can you suggest I do to protect the floor without compromising the benefit of the spikes?
    Cheers,
    Ig
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Do you still play vinyl ? If you don't, there is little to be gained in the use of spikes, since there is little else in a sound system that is likely to be microphonic. If you do still play vinyl, or still want sound damping, then squash balls cut in half are supposed to be very good.
  3. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Being a total cheapskate you could try out pennies under the spikes, it does the job quite nicely.
    You may find this thread useful:
    http://www.avforums.com/forums/showthread.php?t=169500
    Personally I've been unable to hear the benefit of isolating the rack unless you use vinyl or your CD player is ridiculously sensitive.
    In saying that my rack weighs in at about 90KG. The speakers are on concrete plinths isolated from the rest of the room (this did make a big difference!)
