Spikes and stand query
Discussion in 'Home Cinema Speakers' started by pcpaz, Apr 30, 2003.
  1. pcpaz
    pcpaz
    I have a pair of new Eltax Xtreme 400 floor speakers. What's the best type of spikes or stands to place them on, my floor surface is laminated wood.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Try isolation spikes and put each spike on a 2p coin to stop damage to the floor or get some pieces of granite cut to size and and mount the spikes on to the granite.
  3. kenlong69
    kenlong69
    Oct 24, 2002
    505
    Doha
    +6
    Have you looked into Vibrapods? http://www.vibrapod.com Stone's audio sells them. I use them on all my equipment and they would be brilliant on your floor!
    Ken
  4. sounddog
    sounddog
    Dec 11, 2002
    3,360
    107
    Leicestershire, UK
    +452
    Or if you're feeling really flush ... the combination of 2 metals and additional thickness in £2 coins really helps bring out that extra 2pence worth of sound quality from your speakers. :devil: The real audiophile solution!!
    Vikki
