Spike or not to spike
Discussion in 'Home Cinema Speakers' started by RobsterD, Jan 12, 2003.
  1. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Will be running two Rel Q200e courtesy of Timmy B shortly,should I spike both subs on a concrete carpeted floor or decouple the subs by use of the spikes to acheive best results.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    REL supply spikes with their subs then suggest that it's best not to use them, just using the rubber feet instead. :confused:
  3. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Thats what started to confuse me when genning up on sub setup ready for the 2nd sub .Installation notes for the ST series setup suggests "do not use the supplied spikes,using the spikes will decouple the woofer from the floor,which will lean out the base response".Ive now lost the original nylon screws so am unable to test ! Any views would be appreciated .
