Quantcast
spend my hard earned...
N
noddingdino
i've have my eye on a Toshiba 36ZP38 and a Loewe Aventos 32 - any others that are worth a look?
P
Paul Atreides
Have a look at some reviews, or at the least, check the list of ratings at the back of the magazine.
Another suggestion would be to learn a bit about the technologies used in high end TVs, so you can get what you really want.
N
noddingdino
thanks for your help Paul...really all i was after was a couple of other options...are these two worth a look at or am i barking up the wrong tree...etc?
there's a lot of choice out there at the moment! and i always find peoples experiences of things a far better judge of 'real world' use than jargon filled articles!
P
Paul Atreides
If I had that much money to spend I would choose a Loewe or Sony, but that's just my opinion.
Loewe are generally considered to be the best but I've only had a Sony so couldn't recommend any particular model.
