Spend my £2k
Discussion in 'AV Receivers & Amplifiers' started by AngelEyes, Sep 3, 2005.
  1. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,239
    Detached from reality
    +1,514
    With 2K to spend on a 7.1 integrated receiver / amp what would you suggest?
    I am not interested in source switching or any jiggery pokery as by the time I ca afford a projector the technology will have moved on and maybe 1080p will be affordable.
    My priorites are sound quality and power for home cinema listening. I will upgrade the speakers sometime later but a good match with M&K MP150 fronts and column surround rears would be ideal.
    I would even consider seperate processor and amps if the budget allows.
    Thank you.
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    How about an Arcam AVR300 at £1300?
    John
  3. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,239
    +1,514
    It is certainly a beautiful pice of kit but has it enough grunt to get the most out of the M&Ks?
  4. Jase
    Jase
    Mar 16, 2001
    9,536
    UK
    +937
    A Denon A1SRA. Very nice combination with M&K's and it has more than enough grunt to run them. Can be picked up for around 1400 quid if you shop about.
  5. recruit
    recruit
    I would agree with Jase the Denon certainly would have enough power to run the M&K's and at very high levels too, i know this might be a long shot but if you could get hold of an Ex Dem Yamaha Z9 or S/H maybe on Ebay for appox 2K it would be an excellent partner to the M&K's i sold mine at the Beginning of the year for £2000 and it did sound mighty fine with the 851's, i would maybe steer clear of the Pioneer AX10is as they are known to be alittle on the bright side so not too good a match for M&K speakers... :)
  6. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    New Zealand was Nottingham
    +86
    For £2k you could get both a Denon 3805 amp & a Sony HS50 projector. Then maybe upgrade the amp if/when you decide to go the HiDef route. Its the way I would go.
    I had the Denon 3805 (in fact got one un-opened in my garage :rolleyes: ) running my M&K's until this week. They are a very good match for each other I thought :thumbsup:
