ellchester
Established Member
- Joined
- Jan 9, 2006
- Messages
- 266
- Reaction score
- 13
- Points
- 99
I have Gigaclear as my ISP and pay for the 300 MB service. Using Gigaclear's own speedtest I'm getting about 230 down and 240 up on a wired connection. Same with OOKLA but slightly worse.
I have turned off the wifi on the router and I'm using Unifi Acess Points (Pro and Lite). I'm using cat 6 ethernet cable direct from RS components (as recommended on this site) but my speed tests are only coming in at 75 Mb down and 282 up for wifi. I used to get much better speeds, (150-220mb on wifi) when I was always getting a solid 300mb (wired) from Gigaclear but it has slowed in the last few weeks. It's the same with both APs. Even if I plug the AP straight into the router (via POE) I still get the same. My MAC is getting the 230mb and has a TP link gigabit swicth connected to it which I am running the first AP off and getting less than 80mb.
Any suggestions or where I can start to improve speeds?
