Specs for Vita 50 and 100
Discussion in 'Subwoofers' started by nheather, Mar 12, 2005.
  1. nheather
    nheather
    Oct 6, 2004
    20,136
    167
    Horsham, West Sussex
    +10,492
    Can anyone point me at a manual or site that contains the specifications of these sub-woofers.
    Unusually it is the top end capability that I'm interested in. I have some Sony satellites which look nice but only go down to 120Hz. I'm looking to replace the sub which came with them because it barks rather than rumbles.
    It's only for movies, not loud and not expecting Hi-Fi. I expect that virtually anything will be an improvement over the Sony but was wondering whether I will be left with a hole in the frequency range between the sub and the satellites.
    Any one know what the frequency ranges of the Vita's are - I've checked the BK site but couldn't find that info.
    Also interested in the CHT-8 and the Elac 101 (the latter because of the quoted frequency range)
    Cheers,
    Nigel
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
  3. nheather
    nheather
    Oct 6, 2004
    20,136
    167
    +10,492
    Thanks, but as I said, I have already visited the BK site and found that it doesn't give any information on frequency range.
    Cheers,
    Nigel
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    Try emailing BK?
    ...PJ
  5. nheather
    nheather
    Oct 6, 2004
    20,136
    167
    +10,492
    Of course I will email/telephone them. I just thought that as they appear to have a strong reputation on this forum then someone here would know the answer.
    Cheers,
    Nigel
  6. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Sorry, didn't read your post properly...
    The Ruark 50 is the same as MJ Acoustic 50.
  7. nheather
    nheather
    Oct 6, 2004
    20,136
    167
    +10,492
    mhuk05 - thanks for the info
    Did this two days ago - so far no reply - these specs must be a closely guarded national secret!
    Cheers,
    Nigel
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  9. ufitsy
    ufitsy
    Aug 18, 2004
    3,284
    103
    Midlands
    +354
  10. nheather
    nheather
    Oct 6, 2004
    20,136
    167
    +10,492
    For those interested I got a reply from BK today - the vitas go upto 120Hz.
    Cheers,
    Nigel
  11. Mroizouk
    Mroizouk
    Jan 11, 2005
    336
    London
    The MJ acoustics pro range go up to 240hz
  12. nheather
    nheather
    Oct 6, 2004
    20,136
    167
    +10,492
    Yes I noticed that - and I also note that mkuk05 said that the Ruark 50 and MJ 50 are effectively the same thing.
    This leaves confused because BK have stated that the Vitas only go to 120Hz.
    Also assuming that the Vita 50 = MJ Acoustic 50 Pro is there an MJ equivalent for the Vita 100.
    It certainly isn't the MJ Acoustic 100 Pro as that is a very different beast. The MJ Acoustic 100 Ref looks more similar and that does only go upto 120Hz.
    Anyone have a website or contact details for Ruark?
    Cheers,
    Nigel
  13. Member 14718
    Member 14718
    Aug 10, 2002
    376
    Essex
    +25
    Hi nheather
    Effectively they are the same beast, by changing a few caps and resistors on the Vita 50 will raise the frequency to 240Hz. I think I did state in my email to you that we could adjust the upper roll off to suit your needs but the silk screening on the front panel could not change. so Effectively you would have a panel that reads 120Hz and an upper roll off at 240Hz.
    Tom
  14. nheather
    nheather
    Oct 6, 2004
    20,136
    167
    +10,492
    Dan,
    Thanks for the response.
    So for clarification, are these correct
    (a) The out of the box top end for the Vita 50 is 120Hz
    (b) The out of the box top end for the Vita 100 is 120Hz
    (c) The Vita 50 can be modified to increase the top end to 240Hz
    (d) The Vita 100 can be modified to increase the top end to 240Hz
    I did see the comment in your email about being able to make a hardware modification to change the upper roll off but I must admit that I did dismiss it because I assumed that it would be chargeable bespoke modification - is this correct?
    Cheers,
    Nigel
  15. Member 14718
    Member 14718
    Aug 10, 2002
    376
    Essex
    +25
    Hi Nigel
    a) Yes
    b) Yes
    c) Yes
    d) Yes
    It would be a bespoke modification but there would be no charge
    Tom
