Specs for a cheap LCD 15"-any good??
Discussion in 'LCD & LED LCD TVs' started by Gman85, Dec 28, 2004.
  1. Gman85
    Gman85
    Here are some specs of a cheap LCD Tv i might get:
    LCD Panel Type:
    NEC NL 10276AC30-04W
    a-Si TFT Active Matrix LCD
    Panel Size: 15 Inches (38 cm) Diagonal
    Pixel Pitch:
    •0.297 mm
    Luminance:
    •330 cd/m2 (Typical)
    Contrast Ratio:
    •200:1
    Viewing Angle:
    •45°/ 50°/ 65°/ 65° ( T / B / L / R )
    Resolution:
    •1024 * 768 XGA @ 85 Hz
    Signal Input:
    •Analog R.G.B., CVBS (NTSC/PAL), S-Video, TV Antenna, Cable
    Video Output:
    •H&V Separate, Composite
    How does this compare to most 'main stream' brands and what's this tv's weakest link?
