Specific speaker requirements
Discussion in 'Home Cinema Speakers' started by blueraven, Dec 31, 2006.
  1. blueraven
    blueraven
    Aug 15, 2006
    131
    +4
    Hi,Hopefully someone on here will be able to help me with my predicament....
    i am currently using an old sony str-db940 reciever along with the Energy Take 5.1 surround sound speaker package and i need to replace the 2 rear speakers(My rear right is buzzing loudly,and i thought it best to replace both)
    i need a pair of 8ohm speakers that would do the system justice(i'm not too sure of what details you would need to know to help me,but just ask and i'll see if i can get the info for you.
    Many thanks for even reading this
    P.S i spose i should say they are satellites wall mounted
  2. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    6,102
    2
    2
    Bromsgrove
    +623
    Have you tried contacting the manufacturer to see if you can still get them? IIRC they're an American brand that isn't exactly huge over here but is pretty good?
    They may be able to supply replacements or even repair yours? Failing that, i guess these would work? http://www.energy-speakers.com/v2/products/product-page.php?id=35
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    The make of the rears doesn't have to match the fronts- just buy some satellites that you like the sound of.
  4. blueraven
    blueraven
    Aug 15, 2006
    131
    +4
    Yeah,i'd be quite happy to use a different make of rear speakers,but i have no idea about which make/style/specification....?
  5. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    What's your budget? Monopole or dipole?
  6. blueraven
    blueraven
    Aug 15, 2006
    131
    +4
    umm.... about £100 the pair and each one has only 2 wires going to it (2 connections)don't know if thats monopole or dipole (i think that would be monopole)
  7. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    This is a bipole speaker:
    http://www.richersounds.co.uk/showproduct.php?cda=showproduct&pid=MORD-SHORT-903I-CAL
    These are monopole speakers:
    http://www.richersounds.co.uk/showproduct.php?cda=showproduct&pid=WHAR-9.0-CHE
    http://www.richersounds.co.uk/showproduct.php?cda=showproduct&pid=WHAR-8.1SE-BLK
    Just examples not a recommendation (although I have MS903s as rears and think they do a good job and you don't need a stand- they hang from a screw in the wall) and make sure they're front ported (if they're ported).
  8. blueraven
    blueraven
    Aug 15, 2006
    131
    +4
    so....bipolar speakers have speakers situated on two sides? i need monopole speakers then........
    they need to be 100w ,magnetically shielded, NOT bi wirable ,8 Ohms they're gonna be fitted in the corner of the room so if i could get some corner speakers it would be cool!! anything else......oh yes £100 the pair!!
  9. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    If you'll consider used or ex-demo there'll be some bargains here:
    http://www.avforums.com/forums/showthread.php?t=248991
    otherwise visit some shops for a demo or try the usual online suspects.
    Decent brands for around £100 inc. Canton, Mordaunt Short, Monitor Audio etc. etc.....
    Good Luck :)
