Specific Pronto codes required for Toshiba SD900e DVD Player
Discussion in 'Home Cinema Control & Remote Controls' started by Peter Webb, Nov 3, 2001.
  1. Peter Webb
    Peter Webb
    Hi,Does anyone have or know where i can get a ccf file that includes codes to toggle Component output between interlace /progressive,and also toggle video on/off for this (or any eqivalent player).This is the Toshiba with the display that drops to enable the draw to open and close.
    Toshiba shipped the wrong remote control with my unit and i'm waiting for a replacement,and these two functions are not on the remote supplied. I have an RU890 pronto.
    PS.I have tried RemoteCentral without success,but if anyone with this player and a Pronto could create a file for these two buttons and send it to me i would be really grateful.
    Many Thanks.
