Spec OK?
Discussion in 'Desktop & Laptop Computers Forum' started by Mr.D, Nov 7, 2000.
  1. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,210
    900MHz Tbird
    Abit KT7 motherboard(RAID version)
    512MB PC133 RAM
    Asus AGP V7700 Ge-Force-II DDR Deluxe (32MBversion)
    Memorex DVD/CD-RW combi drive
    46GB HD
    Soundblaster 1024
    iiyama pro510 22" monitor.
    Windows 2000 OS
    I'm assuming I'm covered any suggestions?
    Its not really for watching movies on but I figure in about 3 years I might be feeding it into a projector. Audio isn't a priority at the moment.
    I know jack about PCs other than what I found out to put the above spec together.
  2. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    In three years time it is unlikely that you will be using that machine in that configuration anymore...
    512Mb Ram is overkill for all except the most diehard techie NT Oracle programmers ... 128Mb is generally enough for most things, 256Mb is more than enough, 384Mb (what I have) is silly but the memory was very cheap at the time and one of the guys that I bought a 128Mb stick for dropped out so I kept it.
    The 46Gb hard disc is probably more than you need now unless you're planning to rip movies to the hard disc and play them from there. If you're looking for sheer numbers then there's a nice 75Gb 7,200 rpm drive from IBM which is very quick however also very pricey for an IDE drive.
    Phil
  3. HT Dude
    HT Dude
    Agreed - in three years time your PC will be obsolete.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,210
    Yes which is why I'll be using it to run prog scaled dvd into a projector.
    Initially its for compositing motion picture film res images and maybe a bit of 3D in Maya hence the ram (I could do with a gig but thats my max at the mo)
