andyr300
im looking to replace my current PC soon-ish...i will want one that is HDCP compliant throughout and quiet enough that i can sleep with it on a few metres away (but by no means needs to be 100% silent), and can play a 1080p media file with absolutely no slowdown or jerkiness (and preferably be able to upscale using ffdshow to 1080p)!is this reasonable?
Main uses would be TV through MCE, DVDs, Xvid/x264 movie files, and a bit of email/internet.
To start i would just use my DVD-RW drive from my old PC,but in a few months ill replace with a blu-ray or HD-DVD drive (when they are a bit cheaper) (hence need for HDCP compliance).
im thinking about the following costs as en estimate:
case - £100
PSU - £100 (fanless?)
GFX - £100
CPU - £150
Memory - £150
Mobo - £100
sound - £40
HDD - £80
is anything missing from there?and do the approx costs seem reasonable or too high, or might i be better off buying pre-built?any guidance would be appreciated.
case - £100
GFX - £100
CPU - £150
Memory - £150
Mobo - £100
sound - £40
HDD - £80
