speakers
Discussion in 'Home Cinema Speakers' started by marke weekes, Jan 24, 2001.
  1. marke weekes
    marke weekes
    It is advisable to wall mount the Boston micro 90x's? I have the correct brackets but I am unsure of the sound quality that mounting them 6 feet up a wall would produce?
    They currently sit on top of purpose bulit cabinets on opposite sides of a chimney stack,but I would like them to be less obvious. Sub is Q100 if that helps.
    Marke
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    If you are wall mounting your front speakers it is advisable to have them at ear level, so not really higher than 4 foot off the ground. The rears can be higher, upto 6 foot up.
    Rick
    'I am just a figment of your imagination.'
    Work Site: The Sound Gallery
    Home Site: WD A.V.
