Quantcast
Speakers up high or down low ?
J
jjj
I am about to lay some speaker cable in a room for a 5.1 layout, my question is about positioning the speakers. I have read that the speaks should be mounted at around head level when seated, but what effect will it have if i mount the speaker up high on the wall and point them down ?
what about the center speaker, I am putting in a project and screen so don't have a tv to mount it on/under will I get a good sound if i mount it on the ceiling and point it down ?
I don't want the speakers to low as the room will also be used by the kids to play in.
by the way I have Mordaunt-Short Premiere speakers
thanks for any help/advise
John.
ridd
General Thinking is that surrounds should be 2-3 feet above listeners ear level.
Dfour
Dolbly state that the ideal speaker placement is 2-3 feet above seated head hight. :lesson:
J
jjj
Thanks for that link - a useful item
However does anyone have any experience of mounting front and Centre speakers near the ceiling and how does if effect the preformance ?
