Speakers to match Sony STR-DB790
Discussion in 'Home Cinema Speakers' started by rupbert, Dec 17, 2003.
  1. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Have a Sony 28FX widescreen, Sony NS305 DVD, and currently they pass through an old, but to my ears decent Sony Hi-fi system...
    Have recently become a DVD addict, and I am interested in adding some high quality 2.1 OR 5.1 speakers.
    After reading the highly praise worthy review of the STRDB790 in the latest Home Cinema Choice, and loving its looks I have decided this is the budget receiver for me :)
    Now I need some excellent speakers to go with the system. My room is not ideal for a 5.1 setup, its large but has some awkward angles. So I think 2.1 is the way to go...
    My budget is around £200 for the speakers, not including cables. I guess Mission, Kef and Tannoy are a good place to start.
    I want ones that are good for DVD, but equally as important, is music playback. Advice is most welcome...
    Cheers, Steve
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,560
    Edinburgh
    +1,265
    We, Sevenaoks in Edinburgh, are currently selling the Tannoy FX 5.1 package for £250 which would make a good starting point for a Home Cinema setup.
  3. stevej
    stevej
    May 21, 2003
    189
    +3
    I bought this amp a couple of weeks ago. I'm running it with Kef's accross the front, cheapo Gale's across the back and a Vibe subwoofer. I'd try to pick up a sub/sat package then try to get an additional speaker for the centre rear. Or, if you're not in a rush look around for second hand speakers, I've picked up some bargains over the last couple of months.
  4. kiddi
    kiddi
    try to pick some "dark" sounding speakers, they will balace nicely with the "bright" sound of the sony.
    I have the str-db790 and it sounds great with my B&W 602's...;)
  5. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Thanks for the replies guys...
    I remember a while back being interested in the 602's, but it was only on a window shopping level...
    Tried looking for a dealer in the UK (Website) and could not find any that stocked even the B&W range!
    Any ideaS?
    Ta
  6. james4001
    james4001
    Dec 14, 2003
    43
    11
    I was considering buying a sony STRDB790 and a tannoy speaker package with MX3's for the front MX1's at the rear and a MXC in the centre do you think they match the sony reciever and are they good value at £240. would they be ok for cinema use without a sub because the mx3's are rated at 35hz?
    any thoughts would be appreciated
  7. lynx
    lynx
    Jan 20, 2002
    4,636
    It always rains.
    +302
    Mooving to speakers.
  8. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    Seem to be excellent value at £240 and whilst you don't need to have a subwoofer the addition of a decent sub would be the icing on the cake.
  9. Family Guy
    Family Guy
    Mya advice would be to avoid Mission speakers with this amp. Missions have a natural bright sound...with a lot of treble. I tried this amp with my Mission 77 series and they didn't compliment each other in the slightest. However, I'm kind of attached to my speakers so the amp went back for a refund. I now have a THX amp, which, with THX engaged all the time, tames the treble of the bright Missions with it's timbre matching...
  10. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Thanks for that mate, would the Tannoy MX3's be better suited then? They seem to get quite some acclaim :)
