Speakers to match a Linn Classik
Discussion in 'Home Cinema Speakers' started by Shirker, Aug 7, 2002.
  1. Shirker
    Shirker
    Oct 30, 2001
    54
    9
    Leeds
    Can anyone recommend a fair cheap (£200 tops) pair of speakers to go with a Linn Classik. A mate of mine is very keen to get his hands on the Linn and is interested to know what speakers to match with them.
    Out of interest if any Linn owners would like to tell me what they are using then I'd be greatful.
  2. ads1
    ads1
    Mar 13, 2002
    83
    Cumbria
    +15
    Not quite an answer, but several dealers seem to be doing classik/speaker deals, e.g.
    http://www.petertyson.co.uk/offeronclassik.shtml
    I think the classik is worth spending a little more than £200 on speakers though. IMHO, a good starting point would be the Kef Q1s.
    andy
  3. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    I'd definitely try to spend a bit more than £200. For £250 the KEF Q1s are apparently a good bet.
    For better value for money you could look at ex-dem or second hand. For example - Audio Ex (Cardiff Branch) have a pair of second hand Linn Keilidhs advertised at £299:
    http://www.audio-excellence.co.uk/special.html
    The only issue would be whether the Classik has enough oomph to drive them - they require at least 60 watts into 4 ohms. The Classik delivers 75 watts into 4 ohms so I can't see that it would have a problem with the Keilidhs.
    Matt.
