Speakers to compliment a Sony STR-DG910 £200 - £500 range - Help advice or opinions?
Discussion in 'Home Cinema Speakers' started by bealios, Sep 17, 2007.
  1. bealios
    bealios
    Dec 21, 2003
    11
    I thought I would start this thread as I imagine many people are faced with my predicament!
    I've decided to opt for the Sony STR-DG910 for connectivity reasons, I want a user-freiendly full HDMI system where I can connect my PS3, Blu-ray, Sky HD and other consoles without any major problems. I know that the sound quality will not be up there with the STR-DA5200 etc, but as this is my first separates system I'm not prepared to spend £2,000 on an amp and speaker set up just yet!
    So, given that I am aware of the sound limitations of the STR-DG910 (although I've heard from some reviews that it is impressive) I need to sort out some speakers.
    I have a budget from £200 to £500. I would rather pay £200 obviously and I would only want to pay £500 if some of the clever souls on here are sure that speakers this expensive would not be wasted on the STR-DG910 - I'm worried that I might spend £500 on speakers which given sound limitations of amp would not really be worth it.
    I've narrowed choices so far down to the following:
    Tannoys EX5.1 (£179)
    KEF 2005 (£375)
    Mourdaunt Short Genie (£399)
    Mourdaunt Short Alumni (£499)
    Jamo A102 (£186)
    I think the Sony STR-DG will be a popular amp so hopefully this thread and its responses will be useful to others as well.
    Thanks in advance!
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    SVS 5.0, if you can stand the size/looks, are superior to all those, IMO, for £400.
    And definitely don't touch the cheaper end of your list :thumbsdow
  3. SportBilly
    SportBilly
    Jun 18, 2006
    70
    +23
    I am indeed facing the same choice having just purchased the sony STR-DG910 as my first amp and looking to pair it with a suitable set of 5.1 speakers.
    Have you made your choice yet?
    I'm leaning towards the new MS Alumni's. Would these be a good choice or any reason why not?
