speakers - set to "large" or "small"?
Discussion in 'Home Cinema Speakers' started by cliveg, Jan 2, 2004.
  1. cliveg
    cliveg
    Nov 8, 2002
    371
    Hampshire
    +11
    I have the Infinity Oreus speaker package connected to a Pioneer VSX C501 amp.
    When I set it all up with MCACC, it reads the fronts - L, R and C - as "large" and the rear surrounds as "small".
    Now when it sets the fronts to "large" I don't have the subwoofer options available for 100 / 150 / 200htz...only what's called "LS", which gives more bass(?)
    If I manually change the fronts to "small" to match the rears, those options are available again.
    My question is should I leave the fronts as "large" - as per MCACC - or should I manually change them to match the rears :confused:
    ...and what is the significance of "small" and "large"?...the fronts are on stands, the rears are mounted to the walls.
    Any help would be appreciated :smashin:
    Thanks,
    CliveG
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    With speakers set to small all bass is diverted to the subwoofer. As your speakers are satellites and don't go low enough to handle bass they should be set as small with the subwoofer crossover on it's lowest setting of 100 Hz
  3. james4001
    james4001
    Dec 14, 2003
    43
    11
    I was wondering about "small" and "large", does anyone know what the crossover frequency is on small becasue i have some speakers rated at 55hz and some at 65hz and dont know what to set them to small or large
    James
  4. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    It depends on the processor/receiver but generally "Smalls" will crossover at 80hz but may well have an option to change the crosover point to 40hz, 60hz or 100hz. In years of mucking around I've found that for me 80hz works really well for movies as the subwoofer is working more of the time and so isn't distractiong when it "cuts in".
    For this reason I'm going away from "full range" speakers as the lower end ability is largly redundant.
    Most floor standers won't cope well down below 45hz or so and that means with the speakers set to LARGE on the processor some low end effects directed at the mains may be missed.
    Mark.
