J
Jaw3000
Hi! Im a newcomer to home theater systems, and have recently just purchased a home with a system. Just tonight, all of the 5.1 speakers have started popping. The popping is dependent on volume, and changes according to volume level. Also, the popping only occurs when using the TV source (radio, DVD, etc. are fine). Again, before tonight, I havent experienced any problems. My system is set up as follows: I have a Denon AVR-3802 receiver and Aiwa speakers (not sure on the model). The TV source is connected to the receiver via digital toslink. Im not familiar with toslink, so I dont know if a bad cable or a loose connection could be causing this, or if receiver settings or a bad cable box could be the culprit. Obviously the speakers are otherwise fine with other sources, so it would have to be something involving the way the TV source is connected.
Thanks for any help you can provide!
-Jeff
-Jeff
