Answered Speakers or PreAmp?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Dr. Robert, Aug 24, 2018.
  1. Dr. Robert
    Dr. Robert
    Jan 4, 2008
    670
    leeds
    +16
    I'm currently running a merdian 501 pre into a meridian 555 power then B&W cm5 speakers.
    I've just upgraded my DAC to a Chord 2Qute. I have around £1000 left to spend. The question is would I benefit more from an upgrade in preamp or speakers?
    I already have a wanted on this forum for some cm6 s2s but i really fancy a Naim nac 202
    any advice please give
    regards
    The Lad
  2. Best Answer:
    Post #4 by giffordpikes, Aug 24, 2018 (1 points)
  3. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,262
    North east. U.K.
    +1,161
    As a rule, it’s always speakers that make the biggest difference in any given room.
    Assuming of course that the source and amps are up to spec. Which yours emphatically are... so...
    However, as it’s good to be odd from time to time, have you considered something like this?
    Dirac Series : DDRC-24
    I lied when I said it was speakers that make the biggest difference, it’s the room.
    So something that removes the room as much as possible is great idea.
    I would not be without mine.
  4. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,262
    North east. U.K.
    +1,161
  5. giffordpikes
    giffordpikes
    Jul 16, 2017
    251
    46
    Wiltshire, uk
    +174
    Best Answer
    If your amp runs in mono why not get another one and bi amp. That was a massive jump in sound quality for me
  6. Dr. Robert
    Dr. Robert
    Jan 4, 2008
    670
    leeds
    +16
    I've just ordered a Naim nac 202 and NAPSC, See how that sounds. Thanks for advice
