Speakers or headphones with plasma PW6. Buzz
Discussion in 'Home Cinema Speakers' started by Alex., Oct 6, 2004.
  1. Alex.
    Alex.
    Hi all,
    I have plasma TV (PW6) with digital box connected to it. Unfortunately, the box has no possibility of remote volume control. Therefore, I've connected my speakers (also tried with headphones) directly to plasma to be able to control volume with plasma remote control.
    This works actually, but it makes buzz. I can hear that with bright picture on the screen. Making louder - doesn't make buzz louder. With dark picture it is almost not possible to hear it. Also with sound off. Digital box gives clear sound, as it was checked with the same cables and connections.
    I use PW6 connected via JS RGB-VGA converter and integrated sound input without additional boards.
    Has anyone met such a problem? Is it common problem of PW6 or only mine?
