speakers on Panasonic TH-42PWD7BS
Discussion in 'Panasonic TVs Forum' started by rab4169, Jun 22, 2005.
  1. rab4169
    rab4169
    Dec 12, 2004
    533
    ok after alot of searching i think i will go for the Panasonic TH-42PWD7 .
    this set does not come with speakers but i already have hi fi speakers in this room . my question is can i put cable from the plasma speaker terminals into those same speakers so i would have 1 set of speakers on wall with 2 cables going into them. i would not be running hifi and plasma together.
    my only worry is if i use the hi fi would the power go to the speakers on the wall and when continue to the plasma and blow a fuse.
  2. rab4169
    rab4169
    Dec 12, 2004
    533
    anyone help yet
  3. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    errm you dont want the power from your amp going to the plasma. If you have to wire it up this way, you could use a speaker switcher (available from maplins etc).
