Speakers needed, small room though
Discussion in 'Home Cinema Speakers' started by Kirth, Jul 5, 2004.
  1. Kirth
    Kirth
    Jun 1, 2004
    10
    Hey all,
    Having had the fun with play.com and their Kef eggs... I've decided to look at other speakers. Basically atm I have random speakers that are ancient driven by a Denon AVR-1803. I've been trying to decide what to get. Thoughts are the MS Premiere Plus, Genie or buying bit by bit. I did look at the SVS sub's, namely the 25-31 PCi. I have no problem buying bit by bit (in a way prefare it cuz it's safer on the budget!). Since I have no sub atm, I kinda presumed that was the way to go. Over all I dont really want to spend say more than 1k max as I have a kitchen to replace as well ;)
    Genius here forgot room dimensions! It's roughly 3x4(m), but in a slight L shape with openplan kitchen.
    Richard
