speakers loud when the volume is turned up just a little
daven1986
Hi all,
Just got my system set up. I'm running Impule Kora speakers, a cambridge 1 mkIII amp, and a technics pg-590 cd player.
I find that the speakers are the right volume when the amplifier is turned up only a little.
Is this an issue, or is it fine to run the system like this?
If it is an issue, is there anything I can do to lower the volume going into or coming out of the amplifier?
Daven
steveledzep
Your amplifier is available with an optional phono stage (for plugging a turntable in). This is a very high gain circuit. Maybe you've plugged your cd player into this input. Try changing to the aux, tape or tuner input and see if that calms the volume down. Let us know your findings please.
formbypc
If you are plugged into Aux, CD or Tuner etc and it's still too loud too early, look for in-line phono attenuators or an attenuated phono lead to go between CD player and amplifier.
I have a 620 Technics which may be from the same era, and it has variable output level - do you have the remote for yours? Level control on there?
Mark.Yudkin
Unfortunately, you didn't define "a little". On an old fashioned dial such as your Camridge A1 has, 9 o'clock would be considered normal, even though that's well under one quarter of what's available. So if that's where the dial is, it isn't "a little". By contrast, if "a little" meanss that even the smallest twist causes a huge volume, you may have an issue (or have the CDP connected to the turntable input, which should also sound horrible), and you should post back for further assistance
It's only when you reach modern setups having a logarithmic volume control that larger angles become common.
juggler
I was recommended some of these and they work just fine - not a dramatic difference but enough to really increase the range.
ISTR that they are nearly the same price as your amp, though...
BlueWizard
First, does your CD player, which we assume is the source causing the problem, have both variable and fixed outputs. As someone mentioned some older CD player could have a fixed level output and as an alternative, have a volume control on the CD player to control the output levels. Likely for best results either turn the CD volume down or use the Fixed level outputs from the CD Player.
And of course, maker sure you are connecting the CD player to a standard Line Level Input (CD, Tuner, Tape, AUX) and NOT the PHONO input. PHONO is specifically for Turntables only.
If none of these is the problem, and tell us the position of the dial relative to a clock face when you play at normal volume. For my system, with my turntable, 9 o'clock if fine for quiet relaxed casual listening. 10 o'clock is about right from moderately loud yet comfortable listening. 11 o'clock is for moderately loud party levels.
Now, the output of my combined DVD/CD player is a bit higher. Here about 9 o'clock is pretty loud, so for newer CDs, which seem to be louder, I will play at just under 9 o'clock. For older CDs, about 9 o'clock. That is the equivalent of about 10 o'clock when playing my turntable.
So, we need to know two things -
1.) Is the CD connected to TAPE, CD, TUNER, AUX or similar inputs. It CAN NOT be connected to the input labeled PHONO.
2.) Does that CD Player have both Fixed and Variable outputs on it. If the Volume control on the CD works, turn it down.
In neither of these turn out to be the problem, and we can find no other problem, then some Attenuators similar to the Rothwell attenuator in the link already provided might be the solution. Another source of similar attenuators would be Harrison Labs.
These would be referred to as Line Level Attenuator if you want to do a search engine search. They come in various DB levels of attenuation, you need to decide which is right for you. On one of my amps, the volume control has 'DB' marks on it, so I could compare the number of the setting I need to play at vs the setting of the dial were I would prefer to play, and get some sense of the difference in DB (decibels). 3dB is a slight but noticeable change in volume.
And, give us the volume relative to the position of the volume control dial? But, in general, the 9 o'clock to 10 o'clock range is the normal working range.
Beyond that, it is something of a mystery.
Steve/bluewizard
ozzzy189
We've been through all this before. Anyone who can't get any higher than 10 o clock on a volume knob, or above 40% music volume has cd overloading the pre/integrated amp issues. Attenuation required.
Did anybody get their goldring attenuation cables that you were talking about the last time?
Listening to most albums at 60-75 %, some well produced 24/192 and 24/96 will play perfectly well at 80%.
Just made two helmholtz generators as i had bass issues at 63 hz. This has made a huge difference, music is so much clearer, and enables listening at higher volume with less room acoustic issues.
ozzzy189
ozzzy189
ozzzy189
steveledzep
It may be attenuation that's required, depends which input is being used ? They're called Goldenjacks by the way. They work a treat for me on my mediocre cdp. Can't get the volume past 9 o'clock without attenuation !!
BlueWizard
Yes, if there isn't some other solution and if we can establish the current working setting of the volume control, then likely the Line Level Attenuators is the solution.
But if the CD has a variable output, it could be as simple as turning down the volume control on the CD player (assuming it has a volume control).
These are available from Rothwell, Harrison Labs, and Monacor; and possible others.
http://www.hifigear.co.uk/rothwell-in-line-attenuators-pair.html
http://www.electricalmate.co.uk/proddetail.php?prod=212840
Though you have to determine how much attenuation you need.
Steve/bluewizard
daven1986
Thanks for all the replies.
The amp has no phono socket, and it is plugged into the CD input.
The volume control is just around the 7:30-8 o'clock position (2.5 marks), will get a set of those attenuators I think :)
CD player has only one set of outputs called "line out" (also digital out), and no volume control that I can see, also don't have a remote.
Will report back when I have the attenuators.
Many thanks
Daven
formbypc
thanks,I have found a remote cheaper than the attenuators, however my concern is - could the player already be at the lowest line level?
I've got the SL-PS620, and when I turn it off and back on again, it returns to 0dB (full output) - the level control works in one direction, to lower the output, and has a range of 0 to -12dB
I would confidently expect yours to show the same behaviour, and I'd buy the remote with confidence
formbypc
No, I turn it off as I don't need it on standby while I'm at work!
I decided to get the attenuators for this reason :) will report back when I get them.
Thanks for all the help
Daven
No probs. Try leaving it switched on for a couple of days or so and let us know if you think it sounds better.
daven1986
Got the attenuators today - much better, I set them to -20db and now can turn the volume up to around 9-10 o'clock, which gives me much better control over the sound level.
Thanks for all the helpful advice :)
steveledzep
Thanks for reporting back. Happy listening !
Latest News
LG UltraGear Gaming Monitors get VESA certification
  • By Ian Collen
  • Published
Sony confirms UK pricing for A90K and A75K Bravia XR 4K OLED TVs
  • By Ian Collen
  • Published
LG announces new CineBeam HU915QE 4K laser projector
  • By Ian Collen
  • Published
Movies Podcast | Maverick IMAX Review, 4K Disc News and More
  • By Phil Hinton
  • Published
