Speakers fro Denon 3801
Discussion in 'AV Receivers & Amplifiers' started by pauld, Jan 12, 2001.
Tags:
  1. pauld
    pauld
    Hi all,
    I have a Denon 3801 and B & W speakers but need some new speakers for centre rears for 6.1 use. I know I should try and keep the speakers the same, but wife won't let me spend B & W money anymore!!!!
    I have been offered a pair of Mission 731's or a pair of Acoustic Energy AE100's.
    Will these be O.K with my B & W's , as I'm just using the new ones for rear centre channel use???????
    Thanks. Paul..
  2. Mad Max
    Mad Max
    Don't change the choice of speakers... Change wife [​IMG] oops, sorry [​IMG]
    Ok, more seriously, you better take the time to convince your other part, since the best choice you could have is tonal match all around the back.
    You can also try to start out with only one back speaker (B&W), and in a couple of months buy the second... I bet she won't even notice it [​IMG], and the Denon allows for a 1 speaker setup [​IMG]
    An adult is just a kid with expensive toys.
    Rui
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Get the AE100's, pretty decent speakers, and they are front ported like the B&W's. I am gonna get a front pair for my setup, to go with my AE107c that i'm getting tomorrow.
    Rick
    'I am just a figment of your imagination.'
    MiB 1997
    Work Site: The Sound Gallery
    Home Site: WD A.V.
